January 25, 2023 at 7:34 am
FAQParticipantThe viscosity for acoustic fluid elements 30/220/221 is a bulk viscosity term, not a shear viscosity term. Set up a modal (FLUID30) and harmonic analysis (FLUID80). The excitation for the FLUID80 model could be base excitation for the cantilever beam (for example). Then, check the results (e.g., response at tip) to see if all of the modes of interest can be captured. Once this is done, one can add damping (MP,VISC) in the FLUID80 model to see how the frequencies change with viscosity.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
