Tagged: General, mechanical, N/A, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantSee the presentations attached to this solution. Note this was originally presented as two Webinar in French. The Webex recording can be viewed at : https://ansys.webex.com/ansys-fr/lsr.php?RCID=aebdbe1d600147479b9141323cee2de8 https://ansys.webex.com/ansys-fr/lsr.php?RCID=56ed2b56f6e449e6b478f505d050b7f5 The original presentations in English are also attached
1. 2042345_2014.pdf
2. 2042345_2016.pdf
