April 5, 2023 at 2:31 pm
FAQParticipantIf a user has a large model, these are some tips from SCDM experts to speed things up: 1. Set the rendering down from 5 to 1 in the popular options (File > Spaceclaim Options > Popular) as well as turning off anti aliasing. 2. The best way to improve speed is to create multiple components in the structure tree and do repair/edit on one component at a time.
