January 25, 2023 at 7:34 am
FAQParticipantDynamic relaxation needs to be inserted into the model first. Then bolt pretension can be inserted under dynamic relaxation so the stress from bolt pretension can be added to the model as pre-stress that is in the static equilibrium state.
