March 1, 2022 at 10:44 pm
FAQParticipantCurrently there are Fixed Rotation and Nodal Rotation (which allows fixed or free only) boundary conditions. Be sure that Degrees is checked under Units and use a Remote Displacement to apply a rotation in degrees.
