March 17, 2023 at 1:11 pm
SolutionParticipantRemote point may create fatal conflict with Cyclic boundary conditions. Using beam formulation permit to avoid conflicts but is inaccurate. This solution describes Remote Point special settings which will allow accurate results and avoid fatal error. Keywords: Moment, Cyclic, Fatal, Remote point
1. 2058112.zip
2. 2058112_main.pdf
