March 17, 2023 at 8:59 am
FAQParticipantYou can add texture (in the form of an image file) by going to the Display tab > Color > More Colors > Texture > Add, then browse for the texture image file. Image file formats: (.bmp, .gif, .jpg, .png, .tif)
