Tagged: 19.2, General, mechanical, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantThe force reaction is reported at the mobile node of the bushing joint. If force reaction on all nodes of the model is desired, one can issue “nforce,all” in post-processing and check solve.out or post.out files in model directory. Please refer to the attachment to access the Solution.
1. 2057607.zip
