How is the fatigue factor of safety (FS) calculated in workbench when using either the Goodman or Gerber analysis type and maximum principal stress? Since there are several different ways of doing this, depending on what assumptions you make about increasing load, I would like the actual equations used.
Tagged: 17, fatigue, materials, structural-mechanics, workbench platform
March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attachment(s) to access the Solution.
1. 298556.pdf
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
