Tagged: Explicit - LS-DYNA, mechanical, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantEstimated time to complete is based on the current time per zone cycle and estimated number of cycles still required to run to termination time. Please note that memory allocation might be affecting this time, however this effect would typically be insignificant and one would need to do a statistical study to study the effect that memory allocation has on the estimated time.
