How does one properly input a true stress strain curve with elastic and plastic components into the Engineering Data section of ANSYS Workbench?
Tagged: 16.2, engineering-data, General, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attachments to access the Solution.
1. 2040452.pdf
2. 2040452.zip
