How do you calculate the residence times of different sized particles in the system in steady state DPM calculations?
Tagged: 18.2, fluent, fluid-dynamics, General, MP - Particle Tracking, post-processing
January 25, 2023 at 7:17 am
FAQParticipantUse the DPM sample on the plane of interest. 1.You can create plane using Postprocessing –> Create –> Plane. 2. Use this plane while writing *.dpm file with Postprocessing –> Model Specific –> Discrete Phase –> Sample 3. Using Histogram you can plot time and diameter relation.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
