How do I perform material curve fitting for Ogden hyperelastic foam? Note: I attempted to adapt an old input file (and data files) I once created that successfully define an Ogden hyperelastic model to Ogden Hyper-Foam by simply changing all occurrences of “Ogden” to “foam”. When I did so, I get these messages: *** WARNING *** CP= 9.484 TIME= 13:25:08 Base term is negative in Base^Exponent. Absolute Value of Base Term is Used Then I get a visual C++ runtime library error and ANSYS aborts.
Tagged: 17, hyperelasticity, materials, mechanical-apdl, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attachment(s) to access the Solution.
1. 344503.pdf
2. 344503.zip
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
