March 17, 2023 at 8:59 am
FAQParticipantIn SCDM, when we copy a body with the move tool, the original body and its copy are independent. If we copy a component including the body, the copy is an instance of the original. As far as patterns, these will be linked whether you copy the body or the component. But if you do select only the body, then it will create components and move the bodies into components.
