August 25, 2023 at 12:16 pm
FAQParticipant1. Right-click on the Finite Element Modeler icon 2. Double-click on “Manage Input Meshes” 3. Expand the “Importation” tab 4. Choose an appropriate system from the “Unit System” category Also, for a pictorial explanation, refer to the images in the zipped attachment.
1. 2042139.zip
