April 5, 2023 at 2:32 pm
FAQParticipantIn Workbench, a random vibration analysis needs to be preceeded by a modal analysis. If you have already inserted a random vibration analysis cell in your project page, you can follow these steps: 1. Return to your Workbench Project Page 2. In the cell that says “Random Vibration” on your project schematic, right mouse click the cell labeled “Random Vibration” (this will be cell number 1) 3. From the right mouse click menu, choose “Replace With” > Modal (ANSYS) 4. You should now see your cell labeled as “Modal (ANSYS) 5. Drag and Drop a “Random Vibration (ANSYS)” cell from the project schematic into the “Solution” cell of your Modal branch (this will be cell 6 on the Modal branch). When you return to your Mechanical window and set up boundary conditions in your Modal analysis environment, you should able to see those very boundary conditions available under your PSD load in the random vibration environment.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
