Tagged: 17.2, Ansys nCode DesignLife, DesignLife, fatigue, General, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantPlease refer to the attachments to access the Solution.
1. 2047321.pdf
2. 2047321.zip
