March 17, 2023 at 1:12 pm
SolutionParticipantPlease find attached a solution. By using the nodal force load you can define a load dependent on “Time” and “Y Direction”. The load function is here : 100*exp(-((y-(0.01*time))^2)/(1e-7))
1. 2042903-b.avi
2. 2042903-c.pdf
3. 2042903.zip
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
