June 6, 2022 at 9:57 am
FAQParticipantFor outputting the single value of tension/compression in a spring, instead of the two opposite values at its nodes, you can use the ETAB command as it is a MISC result. O the PRRSOL command prints the reaction forces if one of the nodes is constrained.
