How can we consider only specific modes in the harmonic analysis based on the modal participation factor in Modal analysis?
April 13, 2023 at 7:33 am
SolutionParticipantDetailed explanation of the modal expansion and selecting only certain modes for harmonic analysis is given in the attached document and the demo example provided.
1. 2059284.zip
2. Understanding_Modal_Expansion.pdf
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
