June 6, 2022 at 9:57 am
FAQParticipantThe DSIGNF argument on the /FORMAT command controls how many digits after the decimal points are listed. The default value is 5. You may also need to modify the NWIDTH argument. The /GFORMAT command is used to controls the format of the graphical display of numbers.
