June 6, 2022 at 9:58 am
FAQParticipantSHELL,MID will allow displaying of the results of the middle of the shell. Note that, by default, SHELL181/SHELL281 save only top and bottom results, so SHELL,MID will simply average the two. Setting KEYOPT(8)=2 will calculate and store midsurface results.
