Tagged: 17, General, mechanical-apdl, modeling-and-meshing, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantCAD models imported in wireframe mode can be switched to normal mode by using the /FACET,NORML command (Utility Menu>PlotCtrls>Style>Solid Model Facets).
