Tagged: 16.2, General, mechanical-apdl, structural-mechanics
April 5, 2023 at 2:31 pm
FAQParticipantThis is an undocumented feature on the *GET command. You can use: *get,par,vari,,nvar which will get the number of columns. It is the same as nsets that gets the rows.
