Tagged: 18.2, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantIt is possible to display the bodies colored based on their material assignments. You can select the “Geometry” under “Tree Outline” and then go to “Display Style” under its Details and switch to “Material” mode to see the bodies colored based on materials.
