Tagged: 11, General, mapdl, Mechanical APDL (f. ANSYS), structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantUse the *AFUN command to set the unit system – either RAD or DEG. Then, use the GET command ANGLEK (see APDL Guide Appendix B) to retrieve the angle: e.g., zz=anglek(k1,k2,k3) where k1 is the center/vertex keypoint
