Tagged: modal, modal contribution, psd, random-vibration
June 6, 2022 at 9:58 am
FAQParticipantThe square root of the variance can be used as a mode coefficient. The variance can be retrieved using the *GET,,mode,N,mcoef command. See the sample input below. For those commands to work in Mechanical, you need to save the modal results and MAPDL database file (set the “Keep Modal Results” to Yes under the Analysis Settings and set the “Save MAPDL db” to Yes).
resume
/post1
*get,mcoef_3,mode,3,mcoef
mcoef_3=sqrt(mcoef_3)
/post1
set,1,3,mcoef_3*3 ! contribution of mode 3 to 3 sigma results
/show,png
plns,s,eqv
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
