How can I get around the 1000 mode limit in a spectrum analysis? Can I run the spectrum analysis in segments?
March 17, 2023 at 9:00 am
FAQParticipantYes, you could do a spectrum in segments. The participation factor of each mode is independent of the other modes that are used. If you are using the SRSS combination technique, the segment results can be SRSS’d together using LCOPER,SRSS in POST1. If you are using a method like GRP or CQC, solving in segments does lose the modal interaction between the modes near the cut-off frequency. I think this would be a small error, though.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
