How can I compute A,B,D,E composite matrices in ANSYS. I would like to provide these to other tools? Also, how can I take these matrices I have from other tools and use them directly in ANSYS?
Tagged: 18.2, ANSYS Composite PrepPost, composite, General, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantYes. Please see the attached document and video.
1. 2053185.mp4
2. 2053185.pdf
