June 5, 2023 at 7:05 am
FAQ
ParticipantOne can use command MODOPT. Below is from the help documentation. Nrmkey : OFF : Normalize the mode shapes to the mass matrix (default). ON: Normalize the mode shapes to unity. In WB, insert a command object under Modal. You may need to define other parameters of command MODOPT. Below is an example, MODOPT,lanb,6,,,, on
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- How to include effect of bolt pretension in a modal analysis?
- Presentation on shock analysis using response spectrum and transient dynamics
- In a Modal Analysis of Mechanical, why aren’t the Participation Factors Summary under Solution Information displayed?
