June 5, 2023 at 7:05 am
FAQParticipantWhen you clip the geometry via Clip with Plane, the body color is used in section mode. You can select a desired color using the Clip Face color selector. Plane Properties > Appearance > Clip Face color selector. To switch back to body color, just click on the field next to “clip face” and use backspace to delete the color and click enter. This will set it back to the default body color
