How can a user do an Automatic Save of a parametric analysis run for large models (if individual files do not need to be retained)?
August 25, 2023 at 12:16 pm
SolutionParticipantIt can be done through scripting. Methodology presentation, sample file & script are attached.
1. 2043380.zip
2. Automatic_Save_Options_while_using_ANSYS_Workbench.pdf
