How can a gear noise simulation be carried out in ANSYS workbench Mechanical given new Acoustics module?
Tagged: 19, acoustics, mechanical, Nonlinear mechanics, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantWork flow and a demo example is attached.
1. 2056774.zip
2. Demo_Example_Gear_Noise.pdf
