How can a customer put their own company logo at the top of the automatically generated report in Mechanical?
Tagged: 18.1, General, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipant1.Copy the following folder to a different location: Program FilesANSYS IncvxxxAISOLDesignSpaceDSPagesLanguageen-usReport2006. 2.Specify the location under Custom Report Generator Folder in the Report Options (for example: \servercopied_Report2006_folder). 3. Modify logo.png which is in copied_Report2006_folder
