June 5, 2023 at 7:04 am
FAQParticipantIn GLSTAT, the “global x velocity” is calculated as: x velocity = sum(nodal mass * nodal x-vel)/sum(nodal mass) Likewise for y and z global velocities The summations above are done over all the nodes of the part in question. The Resultant Velocity is the square root of the sum of the squares of the x, y and z velocities. This is similarly done on a part-by-part basis in MATSUM where the quantities are referred to as the “rigid body velocities”, i.e., x-rbvelocity, y-rbvelocity and z-rbvelocity.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
