March 17, 2023 at 1:11 pm
SolutionParticipantWhile setting up unsteady DPM, evaluating number of particles per parcel may be done to avoid particle numbers < 1. This makes the setup unphysical. A very large particle number, on the other hand, may result in issues such as high localized sources. Number of particles per parcel can be evaluated as (parcel mass/particle mass). Parcel mass can be obtained as (injection mass flow rate * injection time-step size/no. of streams per injection). Particle mass can be calculated as (particle volume * particle material density) Please refer to the attached PDF file for an example. The attached spreadsheet can be used to quickly key in data to come up with the number of particles per parcel. Attachments: 1. 2054353-particle-number.xlsx
2. 2054353.pdf
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
