How ANSYS translates the eigenmodes to displacement or stress values? When one change the unit system (say from m to mm) for the modal analysis, the displacement values change to a value that’s unrelated between the two unit-systems.
April 5, 2023 at 2:32 pm
FAQParticipantBy default, the solver normalizes the eigenvectors using the mass matrix or: {phi}^T [M] {phi} = 1. Although, {phi} is reported in length units, its true units are 1/sqrt(mass). 1/sqrt(mass) is consistent with the units for {phi}^T [K] {phi} = omega^2: where omega is the circular natural frequency with the units of sqrt(k/m). If the units are changed in postprocessing, Mechanical just does a simple length unit conversion. If the units are changed before the solution, the eigenvalues must be ratioed by the square root of the masses to achieve consistent results. For example if the solution mass unit was kg and you want to obtain the equivalent result for a solution mass unit of slinch, the eigenvalue results must ratioed by the 1/sqrt(175.1 kg/slinch) or 13.23.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
