Having the Surf154 elements included when the Fsum command is issued is having an impact on the reported load. Is this the intended behavior?
Tagged: 18, apdl, General, Macros/Scripting/UPF, mechanical-apdl, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantFSUM should not be used on surf154 elements.
