Tagged: 17, fluent, fluid-dynamics, Mixture Model, MP - Eulerian MP Flow, multiphase
April 5, 2023 at 2:32 pm
FAQParticipantThis approach works well for the flows where the dispersed particle phase closely follows the continuous phase flow, with the particle relaxation time being much shorter than the characteristic time of the continuous phase flow. The ratio of the particle relaxation time over the flow’s characteristic time, which is Stokes number, is typically required to be smaller than 0.01.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
