June 5, 2023 at 7:04 am
FAQParticipantLS-DYNA stores other history variables in place of “plastic strain” for *MAT_ELASTIC and *MAT_RIGID. Those materials are purely elastic and purely rigid, respectively; they are incapable of developing any plastic strain whatsoever. Thus, the quantities under the heading “plastic strain” should be ignored for those materials.
