For a simulation using hyperelastic materials, when I compare my ANSYS (MAPDL or Workbench Mechanical) Stress/Strain output graph to my input Stress/Strain graph, they do not match. Why?
March 17, 2023 at 9:00 am
FAQParticipantFor hyperelastic materials, the material Stress/Strain data that is input is the Engineering Stress/Strain. The ANSYS output, on the other hand, is True Stress/Strain. So, the user will need to convert the ANSYS output from True Stress/Strain to Engineering Stress/Strain when comparing the input material curve and output Stress/Strain curves. Formulae to be used: Convert ANSYS Output True Strain to Engineering Strain: Engineering Strain = EXP(True Strain) – 1 Convert ANSYS Output True Stress to Engineering Stress: Engineering Stress = True Stress/(1+Engineering Strain)
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
