For a Random Vibration analysis,if I want to know the relative displacements between 2 arbitrary points in my model can I use the displacement results?
April 5, 2023 at 2:32 pm
FAQParticipantIn random vibration,, since the results from the solver are statistical in nature they cannot be combined in the usual way. In random vibration, the displacement is a statistical Gaussian distribution with zero mean, so any location can move x-sigma displacement (usually either 1- or 3-sigma) in either the +/- direction. We do not know the phase of the motions, just statistically how much displacement occurs +/- of a mean zero. The calculated values are always reported as positive. By assuming various +/- values, we can calculate the maximum relative displacement that can statistically occur between two points. We cannot confirm that it does occur. So there is no way to use the random vibration displacements of two points to get an exact relative displacement.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
