September 26, 2022 at 9:53 am
SolutionParticipantError Message: ANSYS Licensing Error
FNE Activation Failed: FlexNet Embedded Action: FNE Generate Binary
Request -> FNE Send Binary Message
FlexNet Embedded error: [1,7e1,8,0[74000008,3c,110001f3]] Generic
communication error.
[1,7e1,8,0[75000001,60,30010255]] General data transfer failure. Peer
certificate cannot be authenticated with given CA certificates
Resolution
Follow below steps to check if DigiCert certificate is available on your machine:
- Download attachment “curl_7_53_1.zip” and extract
- Rename curl.exe.tmp to curl.exe
- Right click on the file ca-bundle.crt and select Install Certificate. Follow the instructions to install the certificate provided by curl.
- Next, download attachment “FneCertTest.zip” and extract. This contains a PowerShell script (FneCertTest.ps1) that checks if DigiCert certificate is available or not.
- Once renamed to .zip and extracted, from Windows Search launch “Windows PowerShell” in administrative mode
- Go to the location where you have unzipped the powershell script
- Enter powershell script name i.e. FneCertTest.ps1 and hit Enter. See below image.
- The above command should return DigiCert certificate.
- If DigiCert certificate is not listed, Download the certificate (DigiCertFederatedIDRootCA.crt) from the Digicert website: https://www.digicert.com/digicert-root-certificates.htm#roots
- Right click on the file (DigiCertFederatedIDRootCA.crt)
- For the “Store Location”, select: Locale Machine
- Take the default response to any remaining questions.
- Once installed, try running Discovery products again.
- Ansys Discovery Hardware Requirements (2026 R1)
- What’s New in Ansys Discovery 2026 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery Subscription license – Command line options
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Licensing Options
- ANSYS Discovery: Compatibility Utility
