January 25, 2023 at 7:17 am
FAQParticipantLevel Set is required for surface tension dominated flows where the spurious currents need to be reduced by improving interface curvature calculation. Level Set is not compatible with polyhedral cells. So if adaption is creating polyhedral cells then it will crash. The workaround is use only VOF method instead of Level Set VOF. Keywords: level set, poly, vof, crash
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
