September 26, 2022 at 10:00 am
FAQParticipantFAQ: Why is the mass moment of inertia reported in units of (length)^5 ?
By default, Discovery SpaceClaim does not assign a material to a new model. The lack of a material assignment also means there is no value specified for density, which makes it impossible to display the result using the typical units for the mass moment of inertia:
The mass moment of inertia for a body can be calculated using the general equation
is the material density,
is the distance from any given point within the body to the axis of revolution, and
is the total volume of the body in units of length cubed.After integrating this general equation, we are left with the following terms and corresponding SI units, for example:
However, without an assigned density, the terms cannot be canceled and thus the result of the calculation is displayed as .
Users may also notice that the Mass Properties tool reports the Center of Volume of a part until a density is specified, at which point the label in the results changes to Center of Mass.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
