September 26, 2022 at 9:53 am
FAQParticipantFAQ: Unable to release / Unassign Discovery license
The license management portal at myaccount.ansys.com is currently experiencing a problem preventing users and/or administrators from using the Release and Unassign functions.
Work Around
Affected users should submit a support request through the Discovery Forum and indicate they need to release a license. The support team will locate the user’s Activation ID and have our admin team release it.
Please do not post Activation IDs to the forum, as the forum is a public space and the Activation ID can be used access the software
- Ansys Discovery Hardware Requirements (2026 R1)
- What’s New in Ansys Discovery 2026 R1
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Changing Named User Subscription or Floating (Enterprise) license option after installation of Discovery products
- Discovery: Black screen with no geometry appears after launching Discovery
- Discovery Licensing Options
- Discovery Subscription license – Command line options
- ANSYS Discovery: Compatibility Utility
