FAQ: In Modal Analysis of Mechanical, why the Participation Factors Summary under Solution Information has not data to display?
April 5, 2023 at 2:32 pm
FAQParticipantWhen PCG solver is used with Future Analyses set to None, the .full file is not written and mode participation factors are not extracted. Solution: change the Solver Type to be Direct or make Future Analysis to be MSUP Analyses. The worksheet summary should be back.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
