September 26, 2022 at 9:58 am
FAQParticipantFAQ: Discovery SpaceClaim – SpaceClaim XL addin
In Discovery SpaceClaim 2019 R2 version, a new addin called “SpaceClaim XL” has been introduced. Below are the salient features of this addin:
- SpaceClaim XL allows extremely large models to be opened and explored within SpaceClaim
- Projects can load multiple models from different file formats to load into a single window
- Assemblies can be explored and sorted before loading geometry into SpaceClaim for editing
Download:
- This addin is available in the form of an app which can be downloaded from ANSYS App Store. You need to use your Discovery login credentials for logging to this app store webpage.
- After logging in, go to the search field and type “spaceclaimxl” then click the search icon to list the SpaceClaimXL app as shown below.
- Click on the SpaceClaimXL section and then the Download button to download the app
Installation:
SpaceClaim XL is an addin to SpaceClaim that can be installed by unzipping the download into: C:Program FilesANSYS Incv194scdmAddins
Before unzipping the files, it’s suggested to unblock the zip file by right clicking on the zip file and going to properties. The need to unblock the download will depend on the security settings on your computer.
After the file is unzipped, simply launch SpaceClaim and you will see the SpaceClaimXL tab in the application. Help for SpaceClaimXL is located within the SpaceClaimXL tab. This help document provides detailed information on how to use this addin. Below image shows the SpaceClaimXL addin with all buttons activated.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- FAQ: Missing Areas of the User Interface in Discovery Live
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
