Tagged: discovery-live, General-FAQ, live-faq, spaceclaim
September 26, 2022 at 10:00 am
FAQParticipantFAQ: Discovery SpaceClaim and Discovery Live offline help document
Please click on the links below to download the CHM file (offline help document):
2020R1
2019R3
2019R1
Unblock
After downloading a .CHM, you may need to first “unblock it” before you can use it. This is a common security measure that most computers will enforce on files that came from a different computer.
To Unblock a .CHM:
- Right-click on the downloaded .CHM file and select Properties.
- At the bottom of the General panel, check Unblock.
- Click OK and reopen your .CHM.
Rename
After unblocking the CHM files, you also need to rename them. Rename “SpaceClaim_2019R1.chm” as “SpaceClaim.chm” and “Discovery_2019R1.chm” as “Discovery.chm”
Copy
After renaming the chm files, copy the files in below directory:
C:Program FilesANSYS Incv193scdm
Now, regardless of online or offline whenever you press F1 key the offline help document will open.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- How to setup a Parameter Study
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
- FAQ: Missing Areas of the User Interface in Discovery Live
