May 15, 2023 at 8:32 am
SolutionParticipantAttached video shows how to extract and edit beams. The process demonstrates beam extract tool, editing beam and its cross-section. Keywords: beam, cross-section, profile, edit
1. 2052854.zip
2. 2052854_Captions-EN.mp4
